3/4 " master brake cylinders
Does anyone know the nuts size for mounting the master brake cylinders to the pedal box. There are 2 for each cylinder. I am installing a clutch cable vs hydraulic clutch, so I only need 4. Been all through the PedalBox component boxes and the Wildwood brake box with no luck. Thanks
I don't have one in front of me to check. But according to the Wilwood instruction sheet, the studs on the front of the pedal box are 5/16-24.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
