Results 1 to 4 of 4
Thread: 818 engine smoke
    818 engine smoke
    2.0 JDM WRX engine smokes when pushed hard but fine if driven normally. Turbo has no play, compression good and vacuum good.Any ideas on what would cause this?
    Apr 2021
    I know Im way late for this, but blow by and PCV system also could be a cause. Normally we start with compression test, than install a catch can.
    Bara
    Virginia
    engine smoke
    Quote Originally Posted by Bara83 View Post
    Bara
    the subi motor has oil RETURN air vents around the motor. this will always cause some smoking.
    59 Fiat 1200 roadster
    1963 alfa 1600 gulia
    1949 MG TC
    3 volvo turbo stick wagons
    restored 1968 firebird 400 convertible
    FFR 818 Chassis #172 pickup 04/16/2014
    Take off oil filler cap with engine running and see if smoke comes from there. Compression test dry then with a squirt of oil in cylinder will tell the tale most times.
    16+ FFR kits and counting!
