Likes Likes:  2
Results 1 to 4 of 4
Thread: Unfinished mkiv cobra for sale
    Dec 2018
    Dublin, CA
    CAR HAS BEEN SOLD
    Unfinished MKIV Roadster for sale
    Factory Five Racing MKIV 1965 Cobra that is in early to mid-stage build. Serial Number F5R1008560RD.
    Asking $17,000 Build is Located in Dublin, CA
    This is a no donor kit with all new parts. It has all the basic kit components too numerous to list including but not limited to:
    • Powder coated chassis in dark gray metallic
    • Body cut-outs
    • Blank dash
    • Pin-Drive Front Suspension, Wilwood 6 piston calipers and 13” rotors
    • Pin-Drive Independent Rear Suspension, Wilwood 4 piston calipers and 12.88” rotors
    • Wilwood Pedal box with balance bar and hydraulic clutch
    • Koni coil over shocks all 4 corners.
    • Power steering rack
    • Leather FFR seats
    • Wood steering Wheel
    • Windshield wipers
    • 4 into 4 headers for a 351w, raw steel
    • Raw steel side pipes
    • Tremec TKO 500 5 speed
    • Quick Time bell housing
    • In-tank fuel pump
    • Ron Francis Wiring Harness
    • Windsor polyurethane molded mock-up block with heads
    Custom modifications include adding a steering column with horn, turn signals, and emergence flashers, passenger side under hood sheet metal fabricated to match the driver’s side. This space could be used to house the fuse panel and relays, and a fabricated drop trunk area. Frame has been tapped for 10-32 screws where the sheet metal attaches to the frame. All sheet metal panel to panel attach using Self-Clenching 10-32 PEM nuts. See pictures for clarification. This allows removal of all panels without having to drill out the rivets. There are no rivets on this car.
    Major components needed to complete the build include an engine and engine accessories, clutch components, Pin-Drive wheels, and tires, radiator, dash gauges. Wheels will need to be 17” minimum to clear the 13” brake calipers/rotors.
    PM me for more information.
    Curt
    Dublin, OH
    sorry to hear. this is a killer deal. GLWS.
  3. Thanks Bitten thanked for this post
    Aug 2021
    I will take it. PMing you
  5. Likes Bitten, mburger liked this post
  6. #4
    Dec 2018
    Dublin, CA
    Car has been SOLD!
    Thank you
