Results 1 to 13 of 13
Thread: Coyote/Ford Performance wiring MIL/Check engine light
    Mar 2021
    Trying to wire in dash light for the ford performance wiring harness on my Gen3 Coyote.....
    The wiring harness comes with an LED setup right next to the OBDII port. I figured that it would be triggered by a 12v wire, but when I tried to tap into it, I noticed that I have 12v to that light is on 100% of the time (even with the motor off) - yet.... the light isn't on? Is this somehow triggered by the ECU tying the light to ground instead of tying it to 12v?
    FYI - I'm not just trying to put an LED on the dash. My gauge setup has a CEL icon built into it, and that is triggered by receiving 12v.....
    Rian
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Yes, the coyote MIL is triggered by the PCM through the ground wire. The red wire should have +12V all the time.
    Prescott, AZ
    Yup, the Ford PCMs use a switched ground. I had the same thing with a 4.6L DOHC engine I put in my MK4. The ABS light was a head scratcher for quite awhile.
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    Glad you caught this early Rian! I grounded my CEL light to the chassis and blew a fuse! I think the Ford engineers knew this might happen so they put a fuse there
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
    Jul 2020
    Spencer, MA
    Use a relay that the Ford ECU will ground to activate thus sending 12 volts to the gauge icon light.
    Prescott, AZ
    Why are you suggesting the need for a relay as it just adds unnecessary complexity? Just apply +12V to one side of the LED used for the MIL light and apply the switched GND output from the PCM to the negative side of the relay and you are done.
    Senior Member Nigel Allen's Avatar
    South Australia
    Quote Originally Posted by Alan_C View Post
    It was a solution suggested by Master tech in the case of the OP needing a positive voltage for the MIL in his custom gauge cluster.
    Cheers, nige
    Gen1 Coyote / TKO600 / IRS
  8. Thanks Mastertech5 thanked for this post
    Jul 2020
    Spencer, MA
    LEDs act just like a regular diode in a circuit. They are one way "valves", so to speak, and have a pos. and a neg. side and must be wired accordingly. If the gauge is already wired to accept a pos. signal to light then using a relay to activate it is a fairly simple way to make that happen. I noticed you mentioned relay in your solution. ECU grounds relay and a pos. voltage goes to the gauge. 1 B+ wire for relay power jumped to one pass through terminal, 1 wire to the CK engine light on the other pass through terminal and one ground wire for the ECU. Use a small low current relay.
  10. Likes Nigel Allen liked this post
  11. #9
    Lilburn, GA
    I have a GEN 2 Coyote. The Coyote installation instructions says "Malfunction Indicator Lamp (MIL) BU ---- Provides +12V to MIL when error state is present". This is lead 4 from the pigtail plug.
    I attached the blue wire to the MIL lamp and connected the second wire to ground. Works fine. Not sure if a GEN 3 is different than a GEN 2
  12. #10
    Folsom, CA
    instead of tapping into #4 (GND) and #16 (12V+) -
    wouldn't it be just as easy to tap into the black/red wires on the MIL - seems to be a thicker wire
    Todd
  13. #11
    Folsom, CA
    another question - pin #4 is chassis ground and pin #5 is signal ground, assume neither would show continuity unless the ECU closes the circuit - correct?
    so to light the CEL/MIL light would it be:
    pin #5 and #16 or
    #4 and #16?
    Todd
  14. #12
    Folsom, CA
    update - JohnK got back to me and verified that it's pin #4 for ground, and pin#6 for + on the CEL
    THANKS!
    Todd
  15. #13
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    Just seeing this, and wondering why toadster's post #10 wouldn't work? I haven't powered my electrical system up but I just tapped into the red & black wires going to the MIL on the Coyote harness (as shown in post #10), and ran those two wires back to my dash check engine light. Wouldn't that work?
    Darryl [dbo_texas]
