Results 1 to 4 of 4
Thread: 33 Hot Rod for sale
    Aug 2013
    33 Hot Rod for sale
    33 Hot Rod, 1,780 miles, Titled, Registered, and Insurance thru Grundy (Georgia)
    FFR specific - car has almost every option available from FFR except Wilwood brakes. Removable hardtop and roadster windshield, power windows, electric door poppers, remote camera system instead of mirrors, has engine side panels, Kirkey tall back seats, Boyd aluminum gas tank, Tim Whitaker Derlin door bushing for no lag/slop in doors, Dan Ruths QA1 adjustable coil overs, aluminum window brace and frame for glass, Vintage heat/a/c (needs to be charged), Fortes hydraulic bellhousing fork clutch kit for T5, UniSteer Electric Steering, FFR dual exhaust with ball flanges, double hoop roll bars, fiberglass glovebox behind seats
    Running gear specific - SBF 306 with AFR 165 heads and Comp Cams XE264HR cam(have build sheet from Precision Engine machine shop), set up with Fast 4-barrel multiport set up, Fast XFI 2.0 engine management system with dual sync distributor for timing control, FAST 36 lbs injectors, March Style Track Serpentine kit, Tremec T5 Transmission with overdrive 5th gear (Overhualin Transmission rebuilt with new bearing and syncros), Wilwood hydraulic pedal cylinder, Ram Clutch, 8.8 rear end with 3.55 Ford Racing gear set Cobra diff and Moser axles, BBK headers, QA1 adjustable coil overs, Riddler Wheels with Nitto 555 G2 tires
    I am sure I am missing alot but let me know if you have questions. Asking $38,000
    Josh
    610-564-9742
    Aug 2013
    pics
    please see the link for the other FFR forumn until I can get the pictures loaded here
    https://www.ffcars.com/threads/33-ho...r-sale.645700/
    Aug 2013
    Sold
    Mar 2021
    Is the car available
    Alan V
