Hi. I'm trying to decide which of the following two locations will work best for the flex brake line bracket. Important to note, based on my e-brake cable routing is one option better than the other (thinking about interference)? I am running the stock e-brake cables with 2015 Mustang GT 13" rotor and calipers. Thank you!
Option 1, others builders have done this, but I haven't seen it done with e-brake cable in my location.
Option 2, as described in the manual.
