Thread: Have I missed this?
    Dec 2020
    Washington, MO.
    Have I missed this?
    I have 2 C-clips & can't figure out where they belong.
    I have assembled all the shocks & used the included C-clips.
    I have attached 3 pics with the size shown.
    I can't find the listed anywhere through the IRS installation section.
    Don't want to miss something that's probably important.
    Nov 2021
    Schertz, TX
    I had 2 extra as well
    Not needed. Not sure why these started showing up a couple years ago.
    Cape Coral, FL
    My first build started in 2018 and had no clips. I had to call and they sent some. Maybe over compensating now?
    Feb 2018
    Maybe for the fuel cap and hose connection.
    Mark III 347/435 hp TKO 3.55 axle
    Gen 3 Daytona Coyote Gen 3 T56 3.73 diff. (In build)
    Superlite SLC LS3 480 hp Graziano Transaxle
    Junior Member eljessup65's Avatar
    Apr 2023
    Mount Pleasant, SC
    Check to see if they fit your front, lower ball joint. They are not called out in the assembly manual but that is where snap rings should be installed.
    MkIV Roadster, Chassis number 10735, Ordered 5/10/23. Delivered 10/1/23. Complete Kit, IRS, 427W, TKX
    O'Fallon, MO
    Quote Originally Posted by eljessup65 View Post
    Sorry nope
