Results 41 to 80 of 106
Thread: Trick Flow
    Nashua, NH
    Yes new headers. I had equal length headers before, nice ones but did not have the big metal flange connecting the outlet ports which made them a royal pain to bolt up to the heads.
    http://johngeorgeracing.com
    Nashua, NH
    Engine and trans are in the car! getting closer
    Mark and Brendan were in town and stopped by to give me a hand
    lots still left to do..
    Apex, NC
    John,
    Why such a tall oil fill tube?
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Challenge Series Director FFSpecRacer's Avatar
    That's what comes with the kit.
    Brian [email protected]
    Great Lakes & Midwest Region Series Director
    Heads arrived this afternoon.....may just be a tad too late to install them for tomarrows race
    Robert
    FFRChallenge car #3
    Nashua, NH
    #48 fired up around 6pm today!! sounds spectacular although I have a a small leak somewhere in the intake because at idle it whistles something fierce.
    PCV and fuel regulator go underneath intake for vacume
    oil fill to throttle body
    tightening middle intake bolt is close to impossible!
    still have to tighty up the plug wires, but she runs great!
    Nashua, NH
    upper radiator hose
    lower radiator hose
    1996 mustang GT radiator
    all ready for body
    Nashua, NH
    Quote Originally Posted by R Walter View Post
    Robert
    FFRChallenge car #3
    take them to the track and swap heads/cam there!
    Member jetsbaby's Avatar
    Chandler, A.Z.
    Where did you get your new short block from?
    Nashua, NH
    Quote Originally Posted by jetsbaby View Post
    http://www.latemodelrestoration.com/...ng-Short-Block is the one I used
    Kirkland, WA
    John, no fair you had help getting your engine in! I assume its all back together, no leaks, and no issues and will pull 340/350 on the dyno this week?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Apex, NC
    I can't wait to see the Dyno numbers too.
    340...jeez I am in so much trouble.
    Nashua, NH
    Dyno appointment this Thurs at 4pm 340hp would so nuts!
    Apex, NC
    Quote Originally Posted by johngeorge View Post
    Will you publish the results?
    Nashua, NH
    Quote Originally Posted by mhoward1 View Post
    Yup always do
    Kirkland, WA
    Yup always do
    Will be interested in the A/F ratio when you get your dyno numbers
    Tony Nadalin
    Nashua, NH
    Dyno postponed for fri night.. Traffic got me late
    Apex, NC
    Bummer
    MKIII #5835 Someday I Suppose's Avatar
    Stanhope, NJ
    John, make sure you leave work early enough today, we want to see those numbers!!
    MKIII #3835 IRS, Anderson Performance 408 Levy T-5 Trans, Team III Wheels
    Paint completed November 2010, passed NJ State Safety Inspection June 21st, Tagged and First Drive 7/1/2011
    Nashua, NH
    hah! 20min and counting for the ride home
    Nashua, NH
    Apex, NC
    watching now
    Nashua, NH
    Sounds SO GOOD! I do have an issue with it and will be back tomorrow to troubleshoot, between 4800-6000rpm it brakes up a little and shows it on the dyno chart, not all the time but most of the time. Seems to be an ignition issue somewhere, tomorrow plan is to try the following (yup, forgot to bring my spare parts to the dyno!):
    -swap out the dizzy/module
    -change ECU
    -swap coil
    -datalog fuel pressure/change fuel filter
    On a plus side engine ran cool never getting over 195deg after multiple pulls (no thermostat, running tiny 1996 mustang gt stock single core radiator.)
    car on dyno
    dyno chart of run that did not break apart. Timing set to about 15 1/2deg, fuel pressure between 52-53psi, water temp at 190, weather - it just stopped raining, outside 45deg, inside probably 60-ish.
    319.17hp, 314.74tq
    more to come tomorrow
    Kirkland, WA
    Good numbers, would be better to see if they will come up to 330 ! Let us know what happens tomorrow
    Tony Nadalin
    Apex, NC
    Don't encourage him. I wanted to see 220 hp.
    Nashua, NH
    Back from the dyno! Changing out the dizzy with a new one fixed my bobble at high RPM.
    Final dyno numbers for FFR#48:
    327hp / 318tq, Minimum weight = 2512lb
    Dyno sheet:
    video of dyno run:
    http://vimeo.com/38694520
    Apex, NC
    Great numbers.
    Kirkland, WA
    WOW John, that is a improvement fom about 11.3 lbs per HP to 7.6 lbs per HP, should make a big difference.
    So what was wong with the dizzy gear? worn, loose? no teeth? in upside down?
    Tony Nadalin
    Nashua, NH
    Not sure what was up with my dizzy.. I assume the TFI module was messed up, had it happen before exhibiting same high rpm issue. It was easier to swap whole distribuitor because I had a spare with the TFI already bolted up.
    Everytime I start the car, I'm still in awe how good it sounds! Cannot wait for vir next weekend.
    Ohh and technically it's 7.7 weight/power.. You forgot to round up
    Stanhope, NJ
    John, very nice numbers for sure, and it does sound awesome. I'm betting there are going to be some surprised faces from drivers in other classes at that first race :-)
    You still doing NJMSP in May?
    Chandler, A.Z.
    What is the total cost of the TF upgrade package?
    Nashua, NH
    Around $3K. Call up Eddi at Trickflow for details.
    Kirkland, WA
    So did everyone just get 1 throttle body gasket? I would assume we need 2 as we have the EGR delete spacer, so 1 between TB and EGR delete and 1 between the EGR delete and upper intake? What did people do?
    Tony Nadalin
    yep just one in the TFS TB. You do need another.
    I made mine. They can be bought.
    Kirkland, WA
    So the valve to piston clearance is VERY close on a stock block as mine was right at 80 thousands (seems to be the minimum that TF requires) for the intake (exhaust does not seem to be an issue since it fits within the valve relief of the piston). So if you have a decked block you may run into clearance issues
    Tony Nadalin
    Straight from TFS...................
    You cannot stick the piston out of the block at all.
    So that means you have 5-6 thousandths that you can deck and still keep the piston below deck.
    Kirkland, WA
    The headers did not align on the heads (same headers were fine on stock heads) the bolt holes were off about 1/32 or so. Had to drill out the holes a little to get them to fit, so that cost me a few hours
    Tony Nadalin
    Kirkland, WA
    What is this and where does it go? This was in the Intake Manifold Hardware Kit. I assume that I can also block off the back 2 vacunm holes (on the under side of upper intake) as I will only need the large hole for the PCV and the smaller one for the fuel pressure regulator, right?
    Tony Nadalin
    Nashua, NH
    Tony,
    I found the instructions online here for the upper/lower intake: http://static.summitracing.com/globa...in-9r%20r0.pdf
    Step 5 has the following which does not apply to us!
    For SN95 applications using Trick Flow low profile
    valve covers: Install the 1/4" circular spacer on the stud
    bolt to properly space the heater hard line. This will allow
    the heater hard line to clear the valve covers.
    Kirkland, WA
    John, thanks.
    No fuel pressure reading on guage (have guage on return side of rail), went to start and have no fuel pressure reading, went to check the input line and it had pressure (as I turned the AN fitting gas started to spew out, and then it was late so had to quit). I did run a KOEO test and nothing showed up but did have a 95 - Fuel Pump Circuit Open-PCM To Motor Ground (M,O) first time but not after that (ran tests several times). I did install a new variable fuel pressure regulator, also I don't have the MAF hooked up yet, but not sure that would make a difference?
    Tony Nadalin
