Results 1 to 5 of 5
Thread: wilwood clutch master cylinder problems in type 3 daytona coupe65 coupe
    Jun 2020
    Anyone else have to replace their Wilwood compact remote flange master cylinder because of leakage? Before i hit 500 miles in my type 3 small block Ford Daytona I had my Wilwood mastercylinder that came in my complete kit started leaking out the rear piston I I kept gaining free play....soon the clutch wouldn't disengage. Replaced the master cylinder with another Wilwwod on and all was good and I was off and driving. 800 miles and 1 year later the same problem again....kept gaining freeplay and before i got home i has no clutch disengagement. Has anyone else had this problem? I installed both as per the factory five instructions...cutting 5/8 inch off the threads etc...I must be doing something wrong.....I have an American powertrain hydraulic throw out bearing, and everything there seems to be working fine...just have had to replace two clutch master cylinders already?????
    Aug 2022
    Portland, Oregon
    I replaced one during my build so far due me being un-happy with the operation, but no leaks. Tilton makes a drop in replacement that should fit the same.
    Norton, MA USA earth
    I would take both apart and see if you can figure out why.
    Mar 2021
    Ohio
    Mine arrived with corrosion on the piston rods. I only realized it when I pulled back the rubber boot to check something else.
    Jun 2018
    North Vancouver, BC, Canada
    I had the same problem happen - clutch master on the hot rod, less than a year in. It happened a ferry ride and an hour away from home. Found a local hot rod shop to help me out. Their comment was this is the third Wilwood master they've seen do this in the last year.... I replaced with the same Wilwood but if it happens again I'll be sure to use something else - it is an absolute bear to get out from behind a gen 1 hot rod dash!!!
    Gen 1 '33 Hot Rod #1104
