Thanks Thanks:  2
Thread: Rear Hatch Adhesive-backed Rubber Trim / Gasket
    Mar 2021
    Do you have a lead on where I might obtain some more of the adhesive backed rubber molding / gasket / edge seal that is provided with the Gen 3 Coupe for the interface between hatch glass and the body? I have scoured the web for that profile and density, and I am now cross-eyed :-)
    I tried a section (left over from the length provided by FFR for the hatch) of that molding at the bonnet / cowl interface, and IMO it is PERFECT!
    Any supply leads muchly appreciated :-)
    Best ... Bob
    Edmonton Alberta
    try Steele Rubber Products I don't have the exact part number, I got some from them a couple of years ago. Look at the peel and stick items.
    David W
    Mkll 4874 built in 2004
  3. Thanks LateApex thanked for this post
    Sep 2021
    McMaster Carr caries a decent variety of automotive rubber gaskets, bulb seal, etc.
  5. Thanks LateApex thanked for this post
  6. #4
    Mar 2020
    I reordered extra from factory five about a month ago. Didn’t like how it laid in the hatch corners. Ended up using the half moon/ D-shaped weatherstripping stripping for the hatch instead. Much neater and easy to lay into the corners.
  7. #5
    Mar 2021
    Agree with your observation on the corners when used in the hatch "channel". It isn't really seen when the hatch is down. The curse of being a builder is we know where all the little bugs or errors or quirks are :-)
  8. #6
    Mar 2021
    Quote Originally Posted by David Williamson View Post
    David W
    I think this is the Steele part number: 90-3523-110 Thanks for the lead!
