Thanks Thanks:  87
Likes Likes:  325
Page 24 of 26 FirstFirst ... 142223242526 LastLast
Results 921 to 960 of 1008
Thread: The race is on - Namrups 65 Daytona Coupe build
  1. #921
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    RHK118 - Yes I am going to liner the wheel well panel pieces. I did all my prep/bodywork before the liner. To do the liner first might cause issues later IMO. Although I believe Paul did it that way without issues. Keep in mind that I built mine to the point where I could drive it for a season before completeing it.
    Scott Pregont
    My Albums
  2. Thanks rhk118 thanked for this post
  3. #922
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Need some upholstery help!
    During the past year my upholstery has delaminated. I used marine grade vinyl with foam padding and 3M 77 and 99 spray adhesive. The foam has sticked like gangbusters but the vinyl has pulled up. The part that has delaminated is a sticky gooey mess. I will need to redo it but I need to figure out what I did wrong first. Did I use the wrong vinyl? The wrong adhesive? Did I wait to long for the glue or not long enough? Should I have used a heat gun to soften the vinyl around the edges?
    Any suggestions are welcome!!
    Scott Pregont
    My Albums
  4. #923
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    I’ve never had luck with spray stuff. Anything two part or from a can is going to be better. Short of having a professional spray set up. Lot of different outdoor carpet adhesives like weldwood.
  5. Thanks Namrups thanked for this post
  6. #924
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    60 degrees at the end of Feb. in the northeast! Who would have thought??
    Finished coating the underside of the body over the weekend in this great weather! Next step is to build a body buck for painting and mask off the undercaoting.
    Scott Pregont
    My Albums
  7. Likes rhk118 liked this post
  8. #925
    Apr 2022
    Miami
    Any reason not to put it on the car and mask off? I think many have painted that way.
  9. #926
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    My painter wanted to paint it off the chassis.
    Scott Pregont
    My Albums
  10. #927
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    I love that you've tackled this yourself Scott. Looks great!
  11. #928
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by rhk118 View Post
    I was going to paint it also but after discussions with my painter I decided to let him do it. My garage just isn't set up properly nor do I have the proper compressor, spray guns, etc.
    Scott Pregont
    My Albums
  12. Likes rhk118 liked this post
  13. #929
    Member dstelter's Avatar
    Jan 2019
    Paige TX
    yep. mine was painted off the chassis as well.
    Doug
  14. #930
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Body and body bucks ready for painting!
    Scott Pregont
    My Albums
  15. Likes 460.465USMC, Peter Ross liked this post
  16. #931
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Started the process of getting the coupe painted. I did most of the bodywork and a member of the upstate cobra club, who lives near me, is doing the painting. Here is a link to the picture gallery.
    https://photos.app.goo.gl/G5ZnxB5DFXBLcewr9
    Scott Pregont
    My Albums
  17. Likes 460.465USMC liked this post
  18. #932
    Mar 2021
    Ohio
    Looking good!
  19. Thanks Namrups thanked for this post
  20. #933
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    A coat of primer/sealer was applied and all of the pin holes were filled with a glaze filler and sanded. The high build primer has been applied.
    Scott Pregont
    My Albums
  21. #934
    Ah, Evercoat Optix. Dries pink, sands to gray. I used it once.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    My 18 year old daughter "voted" to leave it that color..... OVER-RULED!
    Scott
    Scott Pregont
    My Albums
  23. Likes 460.465USMC liked this post
  24. #936
    Feb 2018
    Half Moon Bay California
    I like it. The Mary Kay type 65!
  25. #937
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Rsnake View Post
    You know about Mary Kay??? My "X" was a Mary Kay Director. I enjoyed a couple of trips to Dallas for their convention.
    Scott
    Scott Pregont
    My Albums
  26. #938
    Feb 2018
    All I know about Mary Kay is they had pink Cadillacs that looked identical in color to your car.
    Great job on the build.
  27. #939
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Your correct. When a Director build her team to a certian level they were given a "company car". There were different levels of cars available with the top level being the pink caddy.
    Thanks for the positive feedback on my build. Have watched your videos and would love to see your some day.
    Scott Pregont
    My Albums
  28. #940
    When I used it I posted some pics without explanation and figured it would get some reactions. The comments from forum members did not disappoint
    https://thefactoryfiveforum.com/show...light=evercoat
    It's looking really good Scott!
  29. Likes Namrups liked this post
  30. #941
    Feb 2018
    Scott, a type 65 meetup in the middle of the country, i like it. Kansas City for some BBQ?
    Let's start planning
  31. #942
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    That would be wild!!
    Scott Pregont
    My Albums
  32. #943
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    While the body is off being painted I have been working on a few things on the chassis.
    I was not happy with the battery I had. My first one ended up with a bad cell halfway thru the season last year. I replaced it with the same and just was not happy with it. Cold starts were ok but hot starts scared me. Others have used this same battery without issue but I was not happy. I chose to replace it with a much larger battery which required a new battery box also. This battery has 1150 CCA so it should do a lot better with hot starting.
    I also decided to add remote battery terminals. Will make it a lot easier if I need to jump.
    Scott Pregont
    My Albums
  33. Likes JimStone, Skuzzy liked this post
  34. #944
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Spent the day with my painter today. Here's a teaser of our accomplishments....
    Scott Pregont
    My Albums
  35. #945
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    THE REVEAL
    Still needs clear coats, sanding and buffing.
    Scott Pregont
    My Albums
  36. Likes Kbl7td liked this post
  37. #946
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Wow! Looks great. Can't go wrong with a red sports car
  38. #947
    Feb 2018
    Beautiful. I love red with white stripes!
  39. #948
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by JimStone View Post
    Thanks Jim!
    Scott Pregont
    My Albums
  40. #949
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thank you Sir! Appreciate the support. Coming out better than I had imagined.
    Scott Pregont
    My Albums
  41. #950
    Did someone say red? I've heard of using that color. Looks great.
  42. Likes Alan_C liked this post
  43. #951
    Prescott, AZ
    Sarcasm noted.
    I saw a new Tahoe today with one of the most awesome medium dark metallic reds I have every seen. I will being trying to replicate that color on my coupe. I used House of Kolor products and their semi-candy Apple Red is amazing by itself but it is a bit lighter in color. I think painting the apple red over a black or dark red base should get me close.
  44. #952
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Ya I got that inspiration from somewhere?? Pleased with how the stripes came out.
    Scott Pregont
    My Albums
  45. #953
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Alan_C View Post
    Sarcasm noted.
    That should look awesome.
    Scott Pregont
    My Albums
  46. #954
    May 2021
    Fort Worth, Texas
    Looks great!
  47. #955
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Skuzzy View Post
    Looks great!
    Thanks Skuzzy!
    Scott Pregont
    My Albums
  48. #956
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Applied two coats of the Lizardskin SC today. The Lizardskin CI will be applied tomorrow.
    Scott Pregont
    My Albums
  49. #957
    Looking great Scott!
    Nice work! That wasn't so hard, was it?
  51. #959
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Jeff!
    Scott Pregont
    My Albums
  52. #960
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I was really concerned about doing this and have been putting it off. Because I will be getting the painted body back in a week or two I needed to man up and give it a shot but as you said it wasn't so hard at all! Was easier than anticipated and came out better than I expected. CI tomorrow and then on to the other project I have not been looking forward to .... carpet!
    Scott Pregont
    My Albums
