Thread: Bulb Seal - what's best and available where?
    Mar 2024
    Hi Guys and Gals,
    Wondering the best bulb seal to use and best outlets for purchase?
    McMaster-Carr 1120A56 is what identical to what FFR supplies.
    Jan 2021
    x2 on what Jeff said - they also have some with a slightly taller bulb..
    2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23.
    Senior Member Its Bruce's Avatar
    Houston TX
    I think you're missing the last digit - 1120A562
    By the time I got back to my build, the FFR seal had aged beyond use, so I used this: https://a.co/d/83xqr9u
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
    Quote Originally Posted by Its Bruce View Post
    Corrected
    Folsom, CA
    curious is this the same size as the stuff from Michael's replicaparts.com for the radiator shield?
    I think I lost mine or use some of it for other parts...
    Todd
    Quote Originally Posted by toadster View Post
    If you're talking about Mike's nose aluminum, I've installed a bunch of them. The outer edge that is against the body uses the same but there is a smaller bulb for the edge that is against the radiator.
    Folsom, CA
    yep that's the stuff - thanks!! I'm pretty sure I have the flatter edge stuff against the radiator already
    Todd
