michael everson
Try flipping the plate. Or rotating it. Slots are not in the center on purpose.
Yes, the slots are offset to one side but if I flip or rotate the plate the alignment difference is significantly larger, so I believe the plate is oriented correctly and is how the manual shows it. Since the transmission mount plate that attaches to the polyurethane transmission mount has horizontal slotted holes, I was curious if the adjustment available with those would help true up the alignment.
