Results 1 to 9 of 9
Thread: Coyote Gen 3 Oil Temp with Moroso Oil Pan
    Senior Member 32J's Avatar
    Dec 2018
    Sherwood Park, AB
    Question Coyote Gen 3 Oil Temp with Moroso Oil Pan
    Hi All. I have a Forte's Coyote Gen 3 build with the Moroso oil pan. I'm up in Canada, first drive today, and water temp was between 160 and 170. Oil temp never moved off the bottom stop, 140. When I got back to the shop, I used my temp gun on the pan, and it read around 114F. I think once last summer, when it was warm out and water temp got up to 200 (fan turned on), I might have seen the oil temp gauge finally move off of the low stop and get up to maybe 160. Just curious as to what people are seeing as 'normal' (non-racing) oil temp for the Coyote Gen 3 with the big Moroso pan. Thanks.
    Feb 2018
    Half Moon Bay California
    When Cruising in my coupe in 70 degree weather oil runs 140 give or take. Once I flat bottomed the car the Temps now run 175 which is where I want it. At a sustained 135-140 mph I see 200-210 and on track its 205-220 depending on outside temps. I installed an oil cooler but never hooked it up as its not needed. Water runs 180-205 depending but has never been over 205. Now the differential is another issue.
    Dec 2018
    Sherwood Park, AB
    Sorry, don't know what you mean by "flat bottomed?"
    Part of my reasoning for asking about oil temo is that I want to make sure the sensor or gauge is not defective.
    Oil temp is very dependent on RPMs so when you're just cruising 140ish is quite common. Start twisting it's tail and it will rise rapidly.
  5. Thanks 32J thanked for this post
    Grand Rapids, MI
    What diff? What temp?
    I'm planning temp gauges for the trans and diff.
    Jim
    Folsom, CA
    my oil temps don't rise much at all to be honest, but I have just been go-karting - I'm betting like Jeff stated, hop on it a bit and temps will rise
    Todd
    Colorado Springs
    Without a cooler, water temp and il temps should be somewhat close to each other.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Feb 2018
    Flat bottom or belly pan as they also call it is to put aluminum sheet under car to make it smooth for Aero.
    I have aluminum installed from the nose to the engine oil pan.
    As for the Diff, I am using the mustang IRS and at a sustained 140MPH it was 250 degrees. We shall see how it does at 165 in about 4 weeks.
    Might need a diff cooler down the road. The trans is a T56 and I don't have a temp gauge but the oil didn't smell good when I changed it out.
  10. #9
    Dec 2018
    Sherwood Park, AB
    Okay, I'm feeling like what I'm seeing during normal cruising is normal. Thanks everyone.
