Results 1 to 6 of 6
Thread: Rotate engine to index bell housing
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Folks,
    Ready to index the bell housing but not really sure how to turn over the engine with all my parts installed. Suggestions?
    Dan
    Current BOM
    Raleigh NC, OIB NC
    Just a thought. Loosen all the belt tension & pull the spark plugs. Long breaker bar on the center damper bolt.
    Kevin
    MKIV #8234
  3. Likes cv2065 liked this post
    Grand Rapids, MI
    Yup ^
    Jul 2021
    Tonganoxie, KS
    Hard to tell, because I can't open the thumbnail (David's working on that), but it looks like his engine is still on an engine stand. Are you asking how to rotate the engine around on the engine stand so you can install your bellhousing and center it, or are you asking how to spin the crankshaft so you can index the bellhousing?
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrok Pro Flow 4, TKX, IRS, Wilwood Big Brakes
  6. Thanks danmas thanked for this post
  7. #5
    Jan 2019
    Mead Colorado
    Rotate the crankshaft so I can index the bell housing.
    Current BOM
  8. #6
    Member Pmieras's Avatar
    Apr 2023
    San Tan Valley, Arizona
    I second this.
    I removed the spark plugs to remove engine compression which made turning the engine over by hand a lot easier
    Kit delivery (3/17/2024)
    FFR Mark IV Roadster (Ordered 11/9/2023)
    408 LS Stroker Powerplant Ready To Rock (link below of the first start)
    https://youtube.com/shorts/dH36tij3HK0?feature=share
