Results 1 to 5 of 5
Thread: A/C Question
    Member dagall's Avatar
    Ocoee, FL
    A/C Question
    I don't think I am going to put a top on it right away. Should I intall the a/c during the build or is it possible to add it later, should I decide to install a top. I drove my Cobra in the Florida heat without a top or heat and it wasn't bad, wasn't real good, but not bad.
    Fort Lauderdale Fl.
    Dont know for sure about the 33 but certainly with hte coupe and roadster you need to do it with the build..........Steven
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Senior Member Arm7419's Avatar
    Sedona Az
    Almost positive you need to install it before you put the body on. It's a tight fit and I gave up and only installed a heater. It'a a real real tight fit !!!!!!
    chuck
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    Tijeras, NM
    You will never get it in with the body on. Well never say never but her is what it looks like installed. Tomwiring and ac plumbing 001.JPG
    Milton,DE
    Install the HVAC prior to the body install.
    Olli
