Need/Don't Need
Wondering if any of the FFR guys have any more input into what's needed or not needed. I've seen the original list, but was hoping to extrapolate that. I now have parts galore all over the place and want to sell/trash things that aren't needed. I realize a complete list can't be made, but assume there is some level of design/concept work where there are more things in the definite NO category.
Hoping that this thread will slowly grow as we get closer to the release date.
• Main body shell (BUT save all bolt-on brackets and hinges)
• All window glass
Assume all related parts (window motor, slide) is not needed? Assume door skins are not needed. What about door handles (inside and out?) Door window switches? Different year WRX had different door cars, door handle trim, and switch panels. Assume few of these parts would be reused (otherwise some model years won't work/require extra work)
• Headlights and tail lights
Is the sub harness attached to the lights needed, or can it be sold with the lights?
• Rear differential
• Driveshaft
• Headliner and interior pillar moldings
Dashboard? Center console? Arm rest? There are lots of stamped/welded brackets underneath these. Are any of these needed?
• Carpets
• Front and rear suspension cross-members
Is the front cross member the engine cradle? I don't believe the front subframe has any suspension parts on it.
• Front struts and springs
Are the rear struts and springs needed? I have coilovers and want to sell them as a set if possible.
• Rear seat cushion and back
The seat with the pass through has several braces behind it. Are these needed? There's also a large brace under the rear seat.
• Spare tire
• Fuel tank shell (but keep for fittings and internals)
Are swaybars being used? Mine are massive so I'll likely sell them anyways and get smaller ones if needed.
Airbag sensors/module?
Windshield wipers?
Map light?
Dome light (lol)
OEM radiator hoses being reused?
Trunk?
Looking for this infamous list to. Mainly to judge donor cars prior to purchase. Any news would be great.
The 818 won't use any of the struts. Safe to sell the coilovers. (PM me)
You can see Koni (non-strut style) coil overs on all 4 corners of the go-cart.
Watching the video and tearing stuff down makes me wonder a few more things.
- wiring: Can all airbag/abs wires be weeded out of the harness?
Shifter: Are any of the wrx levers/brackets/arms/bushings used? All of my stuff is aftermarket and worth a decent amount if sold off
ABS: Assume ABS pump isn't needed?
Power Steering: If it's definitely a depowered rack I can sell this (and my custom braided lines), but wondering if I should hold onto this at all.
Interior switches: Mirrors, fog lights, defrost, all of that stuff. Needed?
I would probably be careful about too much speculation on this. I would just retain anything that's not already on their "don't need" list until the list is finalized.
I am retaining everything. What I'm hoping is that someone connected to the project will eventually chime in and see the list of things I've taken off and compared to their list and what I see on the go kart and say "yeah, you don't need this, yeah you do need this". That way I can start selling things or just tossing them and emptying my garage.
Makes sense. But you know as soon as you sell something it's going to turn up as needed! It's just how it always works (for me anyways.. LoL)
Some more things I thought of:
Axles. Which are being used? Fronts or rear?
Wheel bearings: I want to replace all of mine, but they're not cheap. If I know I can replace some outright and others get swapped to a custom bit it would be helpful.
Wouldn't it make sense for them to use the font axles?
As far as fitting I to the trans, yes. I can remember if the outboard ends of the fronts and rears were the same.
818 builder
Mechie 3: The 02 wrx tranny has a male input end with female tranny side axle ends and the 05 tranny input end is female with male axles ends. funny thing is the input ends in the 02 can come out or go into a 05 so they are interchanable. On the wheel bearings (there not cheap), but you will need to swap out all bearings if they need it, you are using the 02-07 wrx subaru oem spindles, (use oem parts!!!!!). I would sell the things you know where not using to get some money, like the trunk and wing, many people want those in wr blue, I got 350 for mine. The airbag system, abs, toilet, and jet tub lol etc are all seperate to the meat and potato's that run the engine, so yes they can not be plugged in, or weeded out. This is why you see some blue tape on the wire harness of the 818.
ps: I have a feeling they might be suppling the harness, all cut to what we need as part of kit, it still does not say we need it, but offcoarse hold on to yours cause this is not fact
Are swaybars being used? Mine are massive so I'll likely sell them anyways and get smaller ones if needed. no sell em
Airbag sensors/module? no
Windshield wipers? maybe i would hold on the the set up
Map light? keep for ****s and giggles
Dome light (lol) hmmmmm lol
OEM radiator hoses being reused? no
Trunk? stop
Q:Shifter: Are any of the wrx levers/brackets/arms/bushings used? All of my stuff is aftermarket and worth a decent amount if sold off
A: I am pretty sure no, but I would hold on to it, not like you can't sell down the road
Q:ABS: Assume ABS pump isn't needed?
A: If you will want ABS than keep it, if not sell it
Q:Power Steering: If it's definitely a depowered rack I can sell this (and my custom braided lines), but wondering if I should hold onto this at all.
A: 1)You will have to de-power the rack yourself if you do not want power steering ( I did mine already if you have questions), you can hold on to it, if you are going to have ps.
Q:Interior switches: Mirrors, fog lights, defrost, all of that stuff. Needed?
A: hold on to this stuff, it might be needed.
metalmaker12
I'm lost here. You say it's all separate from the main engine wiring, they can't be plugged in....but they can't be weeded out. Wondering why you can't cut it out if it's not used. I ditched my airpump and valves years ago and removed all of the wiring and connectors and rewrapped the engine harness. Of course I had to shut off 6 or so codes using an access port.
The 06 axles are all male/male (front and rear). Since the front uprights won't need splines, I'm wondering if they're suppying a different bearing or just a piece that inserts from the back and attaches with an axle nut to secure the hub.
I think I've already sold $1200 worth of stuff off the car.
818 builder
Mechie3
Not plugged in or cut out is what I meant
If you look really close at pics and video of the go kart they have either a cut down cv joint or some type of machined part on the front spindle
818 builder
So if this is accomplished we will be able to put the axle nut on
You have to have the outer CV installed to support the wheel bearing assembly. It could be cut down, but you have to be careful about balance issues.
http://www.youtube.com/watch?v=uN_jVWlSPmk
1:17 in... pause the video. Shows the front wheel assembly.
