After seeing a few build pics of the GTM, shoehorning the engine/tranny into position doesn't look like a lot of fun.. and doesn't even look possible with a body on it. How much trouble are we looking at to replace a clutch for instance? Especially after the body is on it, and it gets a little wear and tear. What are your opinions on engine work, oil changes, routine maintenance etc after the build?
We haven't seen the rear end of the car yet, I imagine it will have a trunk of sorts to access the engine, but if it is anything like the GTM, it looks like it will be a bear to install a fresh clutch every so often. I've had to replace a few clutches in the last few years, none (yet) from my own excessive use, mostly because I buy old and worn out (cheap) used cars to DD. Just looking for opinions/speculation, especially from guys who anticipate track use and/or have experience with the Subaru engines.
Edit: oops, forgot the be.. never really liked bees anyway..
