Wagon /sedan differences
Ok I've seen a few places on here that the wagon has a narrower track. What's makes it narrower. The length of the arms? The mounting points of the arms? What else is different?(axle length?) I have an 05 I'm going to start to strip and I would like to now what parts on the need list need to be replaces. Thx
Control arms and lateral links are shorter. Struts are different to change upper knuckle mounting point. Axles are shorter, but interchangeable. It has been stated that the 818 will accommodate both; no need to replace anything.
