0
0
Run the car without side panels, build manifolds to hang a turbo out each side, down pipes straight down then under the car, discharge pipes merged and run to a blow thru carb or throttle body if fuel injected. Its possible, not much space for intercoolers/heat exchangers, just need to be creative.
