0
0
Mad Scientist
Originally Posted by
fastthings
OK good, thanks you guys.
Your 2nd paragragh states on the LS2,3 there is only the idler, I think you ment tensioner only, Right?
*My plan is to get the engine running with the belt off, and then hook it up prior to the evac and charge as to keep the pump from running dry.
the compressor won't turn unless you apply power to the electric clutch. leave the plug disconnected if you are not sure and it won't turn.
GTM #253 In Process
