Results 1 to 3 of 3
Thread: Fox Body Brake Pedal
    Senior Member Mesa Mike's Avatar
    Mesa, AZ
    I'm looking for a stock 87-93 fox body brake pedal. Just the pedal not the pedal box. So far my internet search has turned up nothing. Anyone out there have one there are not using?
    Norton, MA USA earth
    If you cannot find one, you can use an auto pedal. its identical except the pedal pad is bigger. One cut and its the same as the Manual one. Ebay is full of them. even if you have to buy the whole box. They are very cheap.
    Hey Mike,
    I have one you can have. I changed over to a Wilwood pedal set. Give me a call in the AM.
    WEK.
