Thanks Thanks:  9
Likes Likes:  99
Page 2 of 48 FirstFirst 123412 ... LastLast
Results 41 to 80 of 1908
Thread: Mechie3's 818S
    Senior Member Nuul's Avatar
    Sep 2011
    Indianapolis, IN
    Tuesday I ran out of propane for my heater 5 minutes into it.
    I feel that the hours it spent trying to keep my fat *** warm might be to blame. Sorry about that
    Mechie3's Avatar
    Indianapolis
    Quote Originally Posted by Nuul View Post
    It was keeping me warm too Sunday!
    and Monday
    and some week before that
    and some time before that
    and the steaks I made
    and the fish I grilled
    and the shrimp and...
    I've had that tank since mid summer last year? I don't remember. I'm not worried about it. It was more of a "oh...uh...well, this might get cold". HA!
    Zero Decibel Motorsports
    Check out my new website!
    Mechie3's Avatar
    Indianapolis
    So, I may have lied. I didn't do another paper test fit. Decided to jump right in with an aluminum piece. We have so much of this anodized aluminum sitting around that I could make parts all day and still have stuff left over. I programmed it wrong on the slide portion, so the end ended up being an open tuning fork. It's supposed to be a 1/2 depth cut so another piece can key into it and slide back/forth so I can perfect the location of that second piece. Once that's done, it'll still key in, but the bolts will have through holes, not slots, not mate with. The three bolts holes lined up perfectly (one not shown, forgot it at work).
    Sep 2011
    Indianapolis, IN
    Looks good for a prototype. What other custom pieces are you considering making?
    Mechie3's Avatar
    Indianapolis
    Billet heads.
    Not really. Things I have planned/ideas for:
    Titanium shift knob
    Titanium alternator pulley (like an idiot, I dropped my alternator and bent the steel pulley)
    Aluminum radiator mounts (stock ones damaged in wreck)
    CNC my logo/"team" name on the trans block off plate
    Mount for the Y block and FPR on the front of the manifold
    Mount to put the coolant header tank on the 818 frame (similar to the mount I did for my WRX putting the header tank on the strut tower)
    Mount for a Subaru S202 wing blade
    Other stuff as I get ideas.
    Senior Member JAubin's Avatar
    Goffstown, NH
    Looks good! Always feels nice when everything lines up... makes me think if someone had a CAD model, or at least the major mounting points it would be really nice for designing some of the accessory brackets. Who has a stripped down longblock and a 3d scanner? Heh.
    Mechie3's Avatar
    Indianapolis
    I have a few CAD models on www.3dcontentcentral.com. They're all free for download. Not all will be useful, but they include:
    -8AN and -6AN fuel fittings
    Aeromotive FPR
    Subaru Ball Joint
    Plastic coolant header tank
    Fuel Y block
    I could make a model of the 3 mounting points and put that on there too.
    Aug 2012
    Long Island
    Aeromotive FPR
    Subaru Ball Joint
    Fuel Y block
    nice... I see your fittings bit not the Subaru parts.
    http://www.3dcontentcentral.com/Cont...aspx?id=224424
    Mechie3's Avatar
    Indianapolis
    On the left, above the CAD models, it says in bold "Contributions". Go to the right, and in small letters it says "view all contributions". Then, go to page 2 of the models I've made.
    Alternatively, if you search "subaru" all three models that show up in the entire database are mine.
    http://www.3dcontentcentral.com/cont...tentType=Model
    I'll typically upload OEM stuff I've modeled, but not things I design myself. It's nice when you can find off the shelf parts modeled by someone else, but I'm not going to give away the particulars of my specific designs (with some exceptions, like the cam seal install tool).
    Mechie3's Avatar
    Indianapolis
    Time for some bad cell phone shots.
    Made another part of the mount yesterday. Didn't get to do much though because of volleyball. This piece goes between the mounting ears of the alternator then will bolt to that plate I cnc'd. A third piece will hold up the other side eventually.
    Mechie3's Avatar
    Indianapolis
    Didn't get much done Friday or Saturday. Friday I spend machining parts for an F500. Saturday I spent most of my time at the Indycar Factory for Indy Cars and Coffee. I did make some spacers, buy some bolts, and make a plate to bolt the two halves of the mount together. From here I can take measurements for the final part I need and made adjustments to the first two parts for the final design. It's self supporting enough to take a picture now without holding onto it.
    wallace18's Avatar
    Trenton, Florida
    Nice fab work.
    Exeter R.I
    When you selling them lol, cool idea
    Mechie3's Avatar
    Indianapolis
    I could sell some when I have the final design. I borrowed the main idea from Carl Davey (think that's his name). He had a similar design a few years back but don't think he's made any in recent years.
    Mechie3's Avatar
    Indianapolis
    Made the adjuster today and ordered some rod ends and a left hand tap. One side will have a right hand thread, the other side a left, so it works like a turnbuckle to tension the belt. Ends are tapered for looks, knurling to hand tighten it quickly, then flats for a 19mm wrench in the middle for final tightening.
    Aug 2012
    Long Island
    very cool, round the edges of that tuning fork though.. or install a bucket underneath... free blood donation.
    Mechie3's Avatar
    Indianapolis
    The tuning fork is a mistake. lol. I haven't changed it because I'm going to mock up the entire thing, then make changes to the CAD model, then remachine a new setup.
    Suisun City, CA
    I'm definitely in line if you decide to make more and sell them.
    Mechie3's Avatar
    Indianapolis
    Aluminum bit might have ended up a little long (I did make it .125" over the length I designed it just in case, I can always go smaller) but it works. Just want the alternator as low as possible for fuel rail routing but currently have no where to put the lock nuts. Overall, it works beautifully. Center distance from crank pulley to alternator pulley is adjustable from 8" to 9", give or take. Raising it is as easy as spinning the center. Need to cut down some bolts to fit perfectly. They don't make shoulder bolts with an M10x1.25 thread so I bought some extra long bolts so that they had an unthreaded section to ride in the rod end. For the end that attaches to the alternator I either need to make a sleeve, or turn down a bolt and put an M8 thread (I think) on the end.
    Awesome work
    Aug 2012
    Long Island
    I see in your future.... a new alternator pulley.
    Mechie3's Avatar
    Indianapolis
    Yup. Going to make one out of titanium or aluminum. Like an idiot, I thought it would sit on the motor for 10 seconds while I grabbed a wrench and it fell off a few weeks ago, landed pulley side down. The best part? It didn't cut through the epoxy on the floor.
    Mechie3's Avatar
    Indianapolis
    Haven't updated this in 3 months since I've been busy with other projects. Designed a mount to put my y block and FPR both on the center of the intake manifold. The alternator was moved to the driver side to make room. Now both the feed and return lines will be equal left to right. You can see it, but there are two bolts that go into the bottom of the back side of the FPR as well as the ring mount. These previously stripped out, thus the reason for reinforcing the mounting with the ring.
    May 2013
    Nice! i'll be following your build closely. nice to know there will be at least a few 818's in the Indy area to maybe check out someday. Keep up the good work.
    PS, props on rocking the IMS flag in the garage.
    Bowling Green, KY
    Nice work
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    FPS=...? Fuel Pressure Regulator??
    Mechie3's Avatar
    Indianapolis
    Quote Originally Posted by RelfF2 View Post
    I have 4 indy flags currently: 2009-2011 cententiall era, 2012, and 2013 race flags plus the IMS flag. One flag to cover each time I've been to the race since I moved here in 2009. I didn't know you were in Indy. There's another fellow (wildolive IIRC) on the North side with a early early July delivery.
    Quote Originally Posted by Xusia View Post
    errr.... The only FPS I see on this page is yours. It wouldn't be beyond me to mispell something dumb like that though. It is indeed a fuel pressure regulator (blac/red) and a Y block (blue). The top will feed the back side of the fuel rails, the return is through theh front of the rails.
    Mechie3's Avatar
    Indianapolis
    Found a replacement pulley on NASIOC for the steel one I dented. It's a little bit lighter (whoopty doo!, lol) and the circumference is 25% longer, so it spins 25% slower. Hopefully it's not an issue. It was only $27 shipped used, so I couldn't argue with that. Faster than making my own and cheaper than buying a used steel one.
    Mechie3's Avatar
    Indianapolis
    Made some more parts.
    Long, windy, plastic oil filler tube? Aint nobody got time fo dat! Made an aluminum one. Need to make a cap too. It's smaller, doesn't wind all about, and I flipped the male/female threads around since it would be easier to make this way.
    New compared to stock:
    Jul 2012
    Encinitas, CA
    Nice... do you plan to make more?
    Mechie3's Avatar
    Indianapolis
    I did made one extra, though the threads might be messed up. I make these at work and making parts for profit on their machines is a bit of a no no. Though, sometimes I make parts for myself that I don't end up needing.
    Senior Member AZPete's Avatar
    In a perfect world Mechie3 would live next door to me!
    Jul 2012
    Encinitas, CA
    Do you have a solid model you wouldn't mind sharing? I could get that made locally.
    Mechie3's Avatar
    Indianapolis
    Quote Originally Posted by wleehendrick View Post
    I might. Let me get it quoted at a few shops I work with. If it's at all worth me having a batch made I'll do it that way. If there's no profit to be had using a third party shop I'll share the file. I'd have to sign up to be a vendor at that point too.
    Jul 2012
    Encinitas, CA
    Awesome... if the fab costs are reasonable, I think you could do well selling some of your designs to the community!
    Mechie3's Avatar
    Indianapolis
    Quote Originally Posted by AZPete View Post
    They are still building in my neighborhood.
    Mechie3's Avatar
    Indianapolis
    It's mostly done. Still need to put my 818 logo on the top and chamfer the bottom of the cap so it doesn't look so square. Not sure I'm 100% satisfied. It works, but it's a little tight. Might need to change the ID some more, but I might change from a radial seal to an axial seal. An axial seal would have no resistance until it sealed. The radial seal has drag from the momen it engages until you stop tightening.
    Exeter R.I
    Nice work man, so when you shipping mine??
    Mechie3's Avatar
    Indianapolis
    I redesigned it last night, so I'll prototype that one this week. I'm having a local shop quote it for me to see if it's worth trying to make or just give away the drawings to others. I can't really make parts for profit at work.
    Started on the engine wiring harness. Removed all the wires for the PS pump, air pump and valves, and the evap solenoid. Extended three wires so that all of the engine to main harness connectors are together on one side. In the stock config, two large connectors are on the driver side, and two medium ones on the passenger side. They're all on the driver side now. I ran out of tape, and have to leave for a get together, but I started to bundle an rewrap it. Most connectors and wires will be hidden.
    Got the rear timing belt covers and timing belt on, but on the front middle cover. The dealership gave me the wrong bolts for the front side covers, so I'll have to source some other ones.
    Suisun City, CA
    What are you doing about the atmospheric pressure sensor that is built into the driver side secondary air pump valve? Is there a way to change the offset of the MAP sensor to factor in atmospheric pressure?
