Tko 600/coyote-hydraulic throwout bearing questions
Does anyone have specifics for a Hydraulic throwout bearing set-up, specifically on TKO 600 with the Wilwood pedals on an MKIV? I'm setting up my Coyote and want to go with this set-up. Parts list or kits? Experience with the set-up would be great. Thanks in advance..
Do you mean an internal throw out bearing? I used an external .75 slave with a .875 master on the wilwood pedals. Works well.
www.33coyote.com
Built with the help of my dad and sons
coyote/TKO 600, Wilwood Brakes,Boyds tank, QA1 shocks
Speedhut Gages, rag top, bike fenders, power steering
"Never let physics or common sense get in the way of a good idea"
Forte's Parts Connection
Hi Sd,
I try not to sell any hydraulic throw out bearings. The experience I've had with customers is not good. With a 75% failure rate and the work to just get to it (with a future failure looming ahead again) I make many external slave/fork setups that are easy to install and are very reliable. Any way you operate your clutch it needs to be simple and reliable....
Mike Forte
40 Pearl Street
Framingham, Mass. 01702
[email protected]
508 875 0016
www.fortesparts.com
http://www.facebook.com/home.php?#!/...?v=info&ref=ts
The Early Ford & FE Tremec were also originals from Mike. The Mustang firewall adjustable quadrant kit also is an original from Mike. His latest developements are external slave clutch release conversions & cable release conversions too.
Tremec Elite Distributor for: T-5, T-56, T-56 Magnum & TKO-500 & TKO-600
TKO-500 & TKO-600 Midshifter, Front shifter, offset Corvette shifter and more...
A REAL SPEED SHOP with parts, price & knowledge....
Est: 1981 selling & building performance parts to build your dream car...
FORD RACING & QUICKTIME DISTRIBUTOR. NEW 5 LUG AXLES & BRAKE KITS & NEW 8.8\" REAREND IN BOTH IRS & FOX AXLE.
