Results 1 to 3 of 3
Thread: Head Light Buckets
    Senior Member mikespms's Avatar
    North Miami,FL
    Head Light Buckets
    Head light buckets in my car are paper thin and the mounting inserts loose and pull out. Here is my solution to the problem,I made aluminum mounting plates that are going to be bonded with epoxy and a couple of rivets
    Senior Member Edgeman's Avatar
    Medicine Hat, Alberta Canada
    How thick is that aluminum? Good idea!
    GTM #370
    Car was completed and I have SOLD my car
    http://edgemansgtm.weebly.com/index.html
    Doing what you like is freedom - liking what you do is happiness
    later,
    Doug
    LCD Gauges's Avatar
    Toronto, Ontario
    I'm having the same issue. My buckets are hollow, and there is not enough material to faithfully hold the lights. I've thought about filling them with epoxy, and also using an aluminum ring around the
    lamp assembly similar to what you have shown.
