Results 1 to 11 of 11
Thread: Spoiler attachment......
    Senior Member rj35pj's Avatar
    Marion, IN
    My body and paint guy has concerns that riveting the spoiler to the body may cause the paint to squish out around the rivet and the paint might crack around the rivet. Has anyone has issues like this? Will a longer aluminum rivet ease the pressure? Other suggestions?
    Senior Member Fluge's Avatar
    Ontario
    I haven't dealt with that part yet. I was thinking of drilling the holes in the spoiler after bonding the spoiler to the body but before paint. After paint I was then going to insert and glue the rivet heads without crimping them. This way I have the strength of the bonding and the look of the rivets.
    I still need to consider other options though...
    Marc
    It's just A Matter Of Time
    Marc
    FFR Coupe 434, 347ci, Power Brakes, SAI Mod, 3 link rear
    We used allen head bolts and nuts instead of rivets.
    Agreed SS buttonhead screws w/ nylock nuts let you tighten to just the right amount of tension.
    Marion, IN
    Okay, my body and paint man will be happy. I like the look of the rivets but the job he is doing on my car makes it too nice to risk messing it up with the rivets. Thanks again.
    Senior Member xlr8or's Avatar
    San Diego CA
    I painted over the rivets.
    Super Moderator
    Richmond, ca.
    I used ss button head allens 6-32 machine screws. I just drilled and tapped the body and have had no problems.
    Bourne-Cape Cod, MA
    Dont bolt it to the body, Bolt it to the frame. I used the hood pin brackets bolted to the frame, riveted to the spoiler.(ignore the spring-Bad Idea) This way when you peel it off on a curb you won't ruin the bottom of the body,
    URL=http://imageshack.us/photo/my-images/826/mvc003s.jpg/][/URL]
    I also put a 3/4 Brace across the supports, I welded a square nut into the 3/4 stock and threaded the bolt through the side supports.
    FFinisher/AKA RE63
    Senior Member willy's Avatar
    Gillette, Wyoming
    I take it you are talking about the rear spoiler, so I used rivets but also used some silicone adhesive and had no problem.65 Coupe 002.JPG, 65 Coupe 001.JPG
    Marion, IN
    Thank you for all the replys. I ordered 100 stainless 6-32 button head screws tonight.
    Bourne-Cape Cod, MA
    Quote Originally Posted by rj35pj View Post
    Sorry, Didn't realize you were working on coupe.
    FFinisher/AKA RE63
