Thread: do we need to have wipers in MO
    Senior Member BigLeo69's Avatar
    st. louis, MO
    Question do we need to have wipers in MO
    to pass State Patrol
    Mk 3.1 #6945
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Quote Originally Posted by BigLeo69 View Post
    I took a quick read through this (http://www.moga.mo.gov/statutes/chapters/chap307.htm) and it does not appear that MO requires wipers at all. But, I would make a call to your local State Patrol office and ask. Be sure to write down the date, time and who you talked with (including badge or ID number.)
    Ray
    Junior Member rob tomlinson's Avatar
    Poplar Bluff, Mo
    BigLeo,
    I went thru the 551 inspection in 2006. I was worried but the question never came up. I had a copy of state regulation 11 CSR 50-2.230(1) which states wipers required when equipped by the manufacturer. My plan was to argue that I was the manufacturer.
    Hope this helps,
    Rob
    O'Fallon, MO
    No you do not. None on my car, and it wasnt questioned at Troop C or at the safety inspection.
    st. louis, MO
    Smile okee dokee
    great another issue i won't bother with, except now our posts are in the gulf region, whats up with all the changes i from MO you got to show-me
    Mk 3.1 #6945
    Haven't had wipers since '07 and just went through my 5th inspection last week with no problem.
