Results 1 to 3 of 3
Thread: Pin drive
    May 2013
    Slidell la
    Pin drive
    Hello Donnie again with another question. What is the pin drive exactly?
    Pin drive width is a narrower width to accommodate the pin drive adapters which replicate the original design of retaining the wheel assembly with a threaded center hub and spinners whacked tight with a lead hammer. Original cars used a 6 pin integral hub. Pin drive adapters are 5 lug and fit over the wheel studs to replicate the original design.
    http://www.erareplicas.com/427/wheels.htm
    May 2013
    Slidell la
    Thanks that cleared up a lot next question 17" or 15" torn
