Thread: Need Help Identifying These Parts
    Senior Member karlos's Avatar
    Aug 2013
    Littleton, CO
    Steel, 1/16" thick. Anyone?
    Thanks in advance.
    Jun 2015
    Tampa, FL
    I believe they are cooling fan mounting brackets
    Designed to use only if using a Mustang donor rad fan shroud, with the standard FFR supplied electric fan,
    Ditto On The Fan Support Brackets!
    Aug 2013
    Littleton, CO
    OK, thank you guys. No trip to the powder coater for these, then...
    Quote Originally Posted by karlos View Post
    You also have some goofy looking brackets to install hood pins instead of the hood hinges.
    Save them both because you may hack them up to use for other things down the road.
    I've used my two of the quick jacks to make my sway bar mounts and my hood pin brackets as part of my lower radiator support.
