Results 1 to 4 of 4
Thread: Will this be a problem?
    Jacob's Avatar
    Rogers, AR
    I am concerned that the hose filler location will not be the highest point in the system. Will this be a problem? The picture shows the hose tilting downward but when connected to the top of the radiator outlet that hose will be nearly parallel to the ground. Any help is appreciated.
    [IMG][/IMG]
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    What hose are you using from the T-filler, onward to the rad?
    You can see here how I cut the hose shorter, so that the T filler was still the highest point, although not by a lot. Never had an issue with burping or air in the system.
    Jacob,
    It will be impossible to fully fill the system (water doesn't flow uphill ) and purge air from the system. Bill shows a good example.
    Jacob's Avatar
    Rogers, AR
    Quote Originally Posted by AC Bill View Post
    thanks, I can either cut the hose and install the T making it highest, or get another 90...think I'll go with another 90, to be neater. I was gonna make up the remainder of the hose to the radiator inlet using the corrogated SS tubing from FFR.
    Levy 306
    T5
    2015 Mustang IRS
