Likes Likes:  4
Results 1 to 12 of 12
Thread: FFR discontinued narrow width control arms for pin drive FIA wheels
    Member Zach Bohn's Avatar
    Sep 2021
    SoCal
    I placed my order for 289 FIA kit this week, FFR calls to tell me they are no longer offering the narrow width lower control arm (13") and will no longer offer the FIA pin drive wheels. I can get wheels from Trigo, but not the required P/N 12508 - 1987-1998 PIN DRIVE WIDTH FRONT LOWER CONTROL ARMS. Anybody have a set of the narrow LCA or a source to have narrow LCA manufactured?
    I wonder if you could just mount them in the inner holes on the frame?
    Due to the 289 FIA's narrower track width the LCAs already mount in the inner set of holes, but even if that wasn't the case the pin drive lower arms are about 2" shorter so the difference between inner and outer holes wouldn't be enough to make up that difference.
    CobraboyDR's Avatar
    Jun 2017
    Sounds like FFR is done with pin-drive wheels.
    Very sad and unfortunate.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Long shot, but since they're not planning to make them any longer ask them if they're willing to share the drawings for them so you can have them manufactured locally.
    Oct 2019
    Erin, Ontario CANADA
    Quote Originally Posted by JohnK View Post
    Or reverse engineer an existing set. With enough time and money any material thing can be recreated.
    Jun 2014
    It appears that they just cut off an effective 2" of lateral length from the "standard length" A-arm on the bushing side and gusset them on the other side of the tubing.....
    Standard width #12066:
    Pin-drive width #12508:
    I'm sure making the modification to a standard width set would be a "perform at your own risk" sort of thing...
    - Allen.
  8. Thanks David Hodgkins thanked for this post
    Likes David Hodgkins liked this post
    Pittsburgh, PA
    Sounds like a nice opportunity to convert a standard set to rod ends.
  10. Likes David Hodgkins liked this post
  11. #9
    Port Charlotte, FL
    Jacob nailed it. You get a 2fer. Rod ends and the correct width. Win-win.
    Henry
  12. Likes David Hodgkins liked this post
  13. #10
    Rod ends?
    Looks like a simple mod to shorten a standard pair of LCA's...
  14. #11
    Southport, NC
    Dave Smith, FFR just said these are back on the table. Contact FFR.
    George
  15. Likes Zach Bohn liked this post
  16. #12
    Jan 2015
    Did not know that about the inner mounting holes for the 289- did not see that anywhere, thanks Jeff need to move mine.
