Results 1 to 40 of 96
Thread: Charles's '33 build Page
Hybrid View
    Senior Member crspdsk8's Avatar
    Antelope, Ca
    I finally got the front and rear suspension in place and just need some wheels and tires. I set the seats in place and of course the kids just could wait to test them out.
    Now to some eye candy! lol. I was previously was going to go with some FOOSE wheels but after looking into it more, I decided to go with some Eagle's Boss 338's paired with Toyo Proxes 4+ tires. I went with 255/35ZR-18 on 18"x8" up front and 295/30ZR-20 on 20"x10" in the rear. Before I had the tires mounted I test fitted the fronts to make sure they cleared the brakes as I went with a 4.5" offset to try and get the deepest look I can get.
    Here's the result, they fit perfectly!
    I took the wheel back the next day and had the tire mounted and couldn't wait to get it on the ground!
    Then I had to ask the wife since she always says this to me... Does my tires make my "rear" look to big? lol
    When I had it on the ground of course the alignment was really off. After reading the thread that Dr. Ruth had posted on doing an alignment I made the suggested adjustments and I think I got it pretty close. A little trick I had learn from my dad when I was younger to adjust the toe was to run a string around all 4 tires and then you can see how off you are and which way you it needs to be adjusted. Hopefully soon I will get a motor/tranny and can test how well I did on this alignment then will probably take it by the shop to really get it tuned in. These tires are expensive and want to get the most life I can out of them.
    Once we got everything adjusted, my son help get everything tighten down.
    That is where I stand for now. The next couple days I hope to finish up running the brakes lines, bleed them and get them dialed in as much as I can so they are ready to be tested when I eventually get to go-kart it! Also while I am waiting to get a motor, I want to get the fuel tank drilled and bolted, and I will try and tackle the wiring harness. I am not very knowledgeable in this area by any means and hopefully with some help, I can get this going and speed things up down the road when the motor is in.
    So far, I think the build is going pretty smoothly with the exception of being sore from using a rubber mallet to install the suspension and getting everything torqued down. I am really enjoying it so far and turns out being a build that the entire family can help along the way.
    Charles
    Car is looking great so far. I like your helpers! Nothing like starting them early. LOL.
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    Quote Originally Posted by crspdsk8 View Post
    Charles
    if I could ask... What backspace did you go with on the rear. Also does the 4.5" backspace on fronts allow wheels to turn full lock without hitting the upper control arms... I assume so.
    lovely rims.
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    Antelope, Ca
    Quote Originally Posted by hdnik View Post
    lovely rims.
    Thanks Nick! The backspacing for the rears are 5.50". With the steering at full lock, the tires are about 3/4" from hitting the upper control arms.
