Thanks Tom;
question: when you lived in Quakertown, Pa. did you happen to know John Trumbauer? His family owns the Trumbauers Lawn & Garden supply & also the Victory dealership.
Nevin
Thanks Tom;
Nevin
At my last post is basically how she sits today, I did get a different wiring harness from Art Cuesta at Wire Diet because the Ron Francis harness has only 10 circuits and I need more like 18 or 20 circuits depending on the number of accessories I add. So the next action will be to remove the engine/transmission, get the firewall powder coated, then reinstall the engine/transmission with the FRPP controls pack and start installing the wiring harness.
Merry Christmas everyone,
Nevin
After reading a lot of threads about how the suspension is super stiff and a lot of guys are going with QA1's, etc. I can't quite justify the cost of the QA1's so I'm going a different route, I picked up this tip from the Roadster forum; I purchased a pair of QA1 250 lb. springs from Breeze Automotive, I put the 250's on the rear of the HotRod, then moved the FFR 350 lb springs from the rear to replace the stock 500 lb springs on the front. A couple of guys on the Roadster forum have done this and say it is a good poor mans way to soften up the ride. I noticed that the rear shock body was rubbing on part of the rear end housing close to the LCA mount point so I used the 2 lb. reforming hammer to fix that problem.
I also adjusted the shocks to the softest of the 4 rebound settings.
pictures attached:
Nevin, AKA H. R. Lucky
Hi Nevin, Im build# 523 Sounds like a great option on the springs I've also been concerned about ride quality even considered air bags but that would blow the budget , im sure you will be go carting before me at the rate I'm going, hope it works out for you. Please keep us posted.
