What they said. Thermostat would be easy access while doing the timing belt. Take a look at the cooler above the oil filter. If it's caked in dirt, replace the oring between the oil cooler and the block.
Good call. I plan to get a new oil pan (killer B) and pick up tube, which I recommend for anyone running the 2.5 block's oil pick up tube...seen one of them crack at 40K miles, so now I'm nervous about them. My oil filter had a sandwich block for its oil pressure sensor, and it's filthy above it somehow.
Good advice, thanks all!
