My kit also came with one of each, I sent back the angled one and they've sent a strait. Did you consider making the RMIC and wing mount from aluminum?
We could. There are two issues there, attaching it to the steel strut tower bar will require a slip fit and hose clamps or bolts adding fabrication time and cost, and I'm not certain the aluminum would be able to support a wing.
The maximum potential downforce you can get with a GTC300 wing is just over 1500lbs. running at 120mph. Now we all know that WON'T happen with our cars, but we did build our mount out of chromoly and "tested" it with about 700lbs of humans standing on the back, it was cozy
If all you wanted was a trunk it would be perfect for that. I have a fiberglass guy coming by Monday to help brainstorm some trunk options.
