Thanks Thanks:  2
Likes Likes:  15
Results 1 to 40 of 115
Thread: Lucky's 33 Hot Rod build #524
Hybrid View
    Senior Member rcotner's Avatar
    Aug 2013
    Wilsonville, OR
    Great info Nevin. I like the dynaliner. I sprayed the outside of my firewall with lizardskin. I think, after looking at your pictures, that I will put fatmat vibration insulation on the inside and put dynaliner on top of that. I read on the dynamat web site that dynaliner can be used under the carpet as a carpet pad. Seems like that might be a good solution to the floor heat from the exhaust problem. Any thoughts?
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    Quote Originally Posted by rcotner View Post
    Yes, I plan on using the Dynaliner on the floor under the carpet, it will be awhile until I get to that point though.
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
