0
Originally Posted by
Bob_n_Cincy
Great find ICKY
The below pictures show the locking collar installed. The second picture shows the transmission shortened to the max.
You have me debating on where to connect to the shifter shaft.
As you can see in the second picture almost 6" (eyeball measurement) could be cut off.
Where did that piece come from? I have a transmission case with broken gears that i intended to get rebuilt but would be interested in try to replicate what you see in that photo and sharing what i find.
Edit: found the video you got those shots from.
Mechie3
Hi Mechie3
That will definitely shorten thing by 4 or 5 inches.
I'm going to leave the case the same length as the outer tube shown in the picture. That way if you get bumped, nothing gets hurt internal.
I will attach my shifting mechanism to the other end of the shaft.
Busy right now with my wire dissection.
