0
0
Hmmm - maybe this is why the engine won't hold idle. Will report back once I've changed out all 4 (pulled the 1 spark plug in the 5 minutes I had available before work this morning).
I'm also trying to track down a used V2 Cobb AccessPort so I can revert back to a stock or Stage 1 map. The donor car had Cobb stickers all over it. I assume he had a stage 2 map on, but can't be sure.
I also thought I would share my solution to the Alternator pulley. It's not pretty, but it's just a turnbuckle from menards with the appropriate spacers to get lined up (fairly) close to the same plane. The belt is 28.5" long from Autozone.
818 builder
Originally Posted by
billjr212
Only use NGK's and make sure there gapped right with a feeler gauge.
billjr212
I did this exact same thing to another car years ago.. Unfortunately it WILL fail. The aluminum is not strong enough to take the stress. Excellent idea though. With a different, stronger turnbuckle it will work nicely.
