Not sure it's been mentioned, but be VERY careful not to confuse the two caps. The one on the upper reservoir vents under pressure and draws a return on vacuum. The OEM cap on the radiator only opens under pressure.
818S - #67 (SOLD IT!)
Delivered: 18 November 2013
Go Karted: 29 December 2013
Finished: NEVER!
Subaru fixed that on the forester so you couldn't mix up the radiator caps. They didn't put one on the radiator.
Notice that there is an air bleed hose from the top passenger side of the radiator to the "Engine coolant filler tank" (degas tank) Wayne's hose take cares of that getting the air out of the top of the engine.
http://thefactoryfiveforum.com/showt...ooling-burping
Here is one reference I also show it in my build thread.
