When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
my friend and I decided to try and tackle just building the harness ourselves from scratch. definitely time consuming, using one of my garage doors to post all the diagrams on. From what I noticed, there are very few actual fuses in the main circuits you actually need, kinda crazy to think about. I would also have to say Subaru's diagrams kinda suck imo. Now that we got it going, seems a lot easier than trying to make the stock harness work as it was. My only worry is if we might have deleted something critical for the ECU to function, flash, etc. since we deleted so many things, hopefully it all works out! We basically wired in only what we needed to control the engine and cluster basically, everything else such as lights, etc. we put all on their own separate circuit controlled by a switch panel, is there any issue doing it that way?
