0
0
Originally Posted by
philly15
ok, I wasn't sure if it was just simply a voltage reference back to the ecu that could be replicated. I planned on running my car s2000 style with a key and push button, but wasn't sure if there was a way around the immobilizer.
As Chad said, no way around it but it's pretty easy to basically ignore it like we did with his harness. As long as the box is working and can pick up the key frequency, it'll be happy so you can use any start method you like.
