D Clary
I want to be able to run the fans and the pump when the engine is shut down. This will cool down quickly between sessions.
On the Subaru with factory ECU, If Hot, Do the fans continue to run after the key is off?
Edit: Never mind, I see one side if the fan relays is on the ignition circuit. It cannot run after key is off.
