Results 1 to 37 of 37
Thread: VCP Door mounting Tricks
Hybrid View
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Final door fitting tips:
    I used the FFR supplied aluminum piece to mark the cutout for the door release handle. Then I mount the panel to the door using 10-32 speed nuts and countersunk flat top phillips screws.
    I build a raised plate to mount the door handle to on the door frame and with the handle placed in its cutout, I fully install the panel. I screw the handle to the plate and then remove the panel.
    Senior Member Buzz Skyline's Avatar
    May 2013
    Greenbelt, MD
    Is that aluminum piece just for finding the right place to cut for the releases? Or is it supposed to be installed on the door. The manual isn't clear about that. If it is supposed to be mounted, is it only decorative? Or does it serve a purpose?
    -Buzz
