RM1SepEx
Thanks, Dan. They DO make hardened studs long enough to go straight through 1 1/2" of spacers. AJW is marketing some right now. Are you suggesting that studs that long would be too highly stressed? Regardless, I do like the look of the spacers you pointed me at. How are those working out for you? Are your tires still entirely within the wheel wells? You are running 225/55 -16's, while I will be on 225/50-16's. Seems to me that the actual tire width in the formula winds up being a ratio of profile to actual width. Are your 55 profile tires going to be wider, narrower, or the same as my 50 series tires? I'm sure I can figure this out myself, but I thought I'd toss it out there. Sorry about pulling your thread a little off-topic. I know there's a better place for this question, but I thought I would put it where I knew you would see it.
