Can you post pics of the battery area where your hoses cross into the driver compartment.
I'll have to do it tomorrow. My phone was having problems where it wouldn't charge. My battery is in the back too, so that helps, but it should still work. I made two holes at the front of the tunnel just above where the frame makes a V, one on either side of the center brace. One then goes to the top of the HE, the other goes into the outlet of the pump. The inlet of the pump goes to the bottom of the HE. This makes the pump the lowest point and there are no (or perhaps very very slight) areas where the hose goes up then back down then up to create traps.
Zero Decibel Motorsports
Check out my new website!
