0
i didn't get a whole lot done this weekend, got the rack together and mounted in the chassis, and started fitting the steering shaft and brake booster and pedal box. No issues with the pedal box, but the booster does not clear the frame (I know this), my biggest issue is accessing the master cylinder fill cap after the body is on. I am going to try and do a more exact test fit tonight.
Not a waxer
Originally Posted by
6t8dart
I've built a few cars using the vacuum booster, You can easily reach under the body to remove the master cylinder cap and then to top it off I suggest that you purchase my custom fill device---only $19.95 (cash sales only, I only accept fiftys and hundreds, no change).
Jeff Kleiner
Jeff,
I know that is an old post, but you owe me a cup of tea and a monitor and keyboard cleanup.
