Nice to get it figured out, even if it means a new trip to the BOD. Mine is still on the side of the house, in case I'm not done with part cleaning.
Engine startup with new 1050cc injectors
Engine startup with previous known 550cc EV14s
Well, so far after fitting 1 axle in a yet-not-ready-spindle-but-enough-to-get-the-hang-of-it, it seems I have enough play on all 3 axial dimensions, up-down, front-back and side-side (inner CV extension). Which axial movement exactly were you referring to?
Good point. The plates look ok and as straight as they were before, I'll mention that to my mech when he's change again the bearings, especially the new set will go on the other set of spindles which required removing and reinstalling the plates.
Yeah you never know when this might come handy again!
But plz, I highly suggest anyone not to make a mistake about spindles, it's a pain to play with those all the time and a full set of bearings/seals costs USD$100 with shipping to CAD.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Made some progress this w-e, after removing all the stress about the spindles.
Custom throttle cable bracket to reinstate the cable's tension (not pictured yet), custom overflow reservoir bracket (tnx to my new bench grinder), oil cooler and exhaust. I just need to secure the muffler in place and finish the exit and it's done. Oh crap, the dump tube as well, it will merge just before the muffler, that is a very nice but complicated challenge. Not a problem, just a challenge. I got my parts from Verocious, I'll see next w-e what I can do about that. It'll be a very compact exhaust, all made by myself which I never did before! So far the SS welding is going on really good! I can't say how important that welder is for the build.
2015-11-22 09.24.43_1.jpg2015-11-22 09.30.30_1.jpg2015-11-22 15.00.50_1.jpg2015-11-22 16.00.54_1.jpg2015-11-22 16.01.08_1.jpg
It's impressive how I (and we) can reuse old parts and brackets, modify them and make them look like new parts. There are some 25yo parts I was reusing, some others I had severely modified and yet here's a second life for them! Who would knew...
