20
104
Moonlight Performance
Showing camber setup:
https://imgur.com/UrbX4Hz
Caster setup:
https://imgur.com/cUutzj6
Getting all tires level:
https://imgur.com/Y9tY0oH
What you are looking for:
First check inside, and zero it out here:
http://i.imgur.com/Cx7sam2.jpg
Next check outside and ensure it is still at zero. If so, you are parallel else adjust and recheck.
https://imgur.com/FL5SiCM
One more thing: your laser level device should stay in one spot. You can locate it where it will hit all the blocks or cone close. Use some angle iron as shown in the pic to hang the ruler a few inches off each block if you have to in order to hit the beam (though I didnt need to hang it iff on this side but I did on the other side of the car). If you use the angle on all four blocks whether you need it ir not, it keeps the measurements consistent. Man this is hard to explain, esp typing on a phone lol.
Hindsight
Caster setup:
I appreciate you taking the time to post those pics and explain everything. Believe it or not, I think I understand, lol.
I imagine that to adjust those arms parallel you adjust the upper trailing arm?
Adam _____ Instagram @PopesProjects____
YouTube Channel
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
