For those who are removing or relocating the handle, how are you lifting the trunk lid once it's released? The handles also serves this purpose, and without it, not sure what you'd grab to lift the lid. Once it's finished, the trunk lid is surprisingly heavy, plus it's hinged from the opposite edge. So you have to lift nearly the entire weight when opening. Gas assist struts are possible, but the ones normally used barely hold the lid when open, let alone provide all that much lift assist. It would be possible to use stronger struts, but even in using the standard ones I've found it challenging to get the hinges aligned and the lid closed/flush with the body. The struts pushing against the hinges even while closed doesn't play nice in my experience. I didn't use struts on my last build. Bottom line, very common for changes to affect something else. You almost never can make one change in isolation. The pluses and minuses must be considered.
To the OP, my only comment after following this thread is wait until you get into the build. If this bothers you, I'm wondering how you're going to react to the DS door alignment (or should I say lack of...), the asymmetrical body, radiator mounting, windshield mounting, instrument panel mounting, wiring, side pipe alignment, the list could go on. There are challenges with these build. This isn't one of the big ones IMO.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
