Probably the most typical answer is for normal street cruising, no. If you plan to track or auto-x the car, it's recommended. Having said that, the two builds I've done with PS I went ahead and also installed a cooler even though I'm 99.9% street cruising. It's an easy add during the build and doesn't cost much. Would be much harder to add later.
